Zum Hauptinhalt wechseln
Die Apple Smartwatch der 7. Generation mit optionaler Mobilfunkverbindung, herausgekommen am 15. Oktober 2021.
Will I be able to repair rear cover adhesive without front assembly?
I found a guide for replacing the rear cover/sensor on the Apple Watch Series 7 that instructed removing the front display and battery for swapping the rear cover. However, I do not need to replace the rear cover. It is still functional. The watch charges in the sensor works, but the gasket and adhesive sealant failed and The gasket is hanging out of the watch body, see the attached picture.
  1. Am I missing something other than the rear cover adhesive for this repair.
  2. Will I be able to do this repair without removing the front display and battery?
Thanks for the help!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It’s tricky, the adhesive comes with a plastic backing that is tricky to apply with the rear cover hanging in place.
I suggest fully disassemble, clean the adhesive contact surfaces and apply new factory adhesive.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Tancredo R wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 39
