Zum Hauptinhalt wechseln
Repair information for the Raspberry Pi 1 Model B+. Released in July of 2014. Model: B+.
usb port not working keyboard and mouse is not working
i am not able to connect mouse and keyboard , i think my usbport is not working
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If you think that the usb port is broken, I would suggest first ensuring that the port is clean. If that doesn't do the trick, make sure that the port is well soldered to the motherboard. If the pins in the USB port look bent, see if you can bend them back. If not, I would suggest that you simply replace the USB port---these parts are cheap and easy to solder on
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Thoppi Flix wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 67
