Zum Hauptinhalt wechseln
Eine dritte Version des Controllers wurde im November 2020 zusammen mit der Xbox Series X und Series S veröffentlicht. Dieser Controller ist abwärtskompatibel mit früheren Xbox One-Konsolen und PCs.
Possible to replace stock joystick with Elite ones?
I noticed that the Series and Elite controllers seems to have similar joystick solder pad locations...
I would really like the tension adjustments available in the Elite controller but don't want to buy another since I already own 3 controllers. Would it be possible to swap the Elite joysticks onto the Series controller if the position of the solder pads are the same? It doesn't matter if it won't fit inside the casing, I can simply cut part of the casing to make the tension adjustment joysticks fit, but the main question is whether the joystick are interchangeable. It's hard to tell the exact location in only the pictures and I don't know whether the wipers are identical.
Can anyone who happens to have both the Series and Elite controller or know about the joysticks tell me whether they are interchangeable? I know it's a pretty crazy mod, but it sounds pretty plausible to me.
Thanks in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
This is a really good question! If the solder legs will fit the holes in the board, it's "Most" likely possible that it will work.
For now, I don't own them both and they are also not at my repair site, so it's hard to tell...
I think testing it would be the most easy way to tell for sure.
Sorry Leo!
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Well I suppose we'll see... already ordered TMR versions of the Elite 2 joysticks and I'm planning to install them the moment they arrive.
von
Yesh best thing to do. It’s worth a try. Hopefully it works! Please keep us updated :)! Thanks!
von
yep they work perfectly. thanks for the confirmation!
von
That is great news! Thanks for letting us know :)! Take care!
von
Antwort hinzufügen
Leooooo1061 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 155
