HP-nya tidak bisa menyala dan baterainya kembung sedikit
Translation Indonesian - English
The phone won't turn on and the battery is slightly swollen.
Ist dies eine gute Frage?
@raa123 your battery is failing and it is time to replace it. The longer you wait, the worse it’s going to get. Your battery can further expand and may damage the internal structure of your phone i.e. circuit board damage or even worse, it may vent with flame, basically expand and rupture which may cause a small fire hazard. My suggestion is that you change the battery now.
Since iFixit does not yet have a specific guide for this, use something like this video Instead of a hot plate, you can use a hair dryer or a heat gum to loosen the adhesive on the back cover. Properly dispose of your old battery. Once you have the battery replaced and checked all the flex cables etc., you will need to re-evaluate your phone to see if it turns on again. Let us know what you find out.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@raa123 Baterai Anda sedang rusak dan sudah waktunya untuk menggantinya. Semakin lama Anda menunda, semakin parah kondisinya. Baterai Anda dapat terus mengembang dan berpotensi merusak struktur internal ponsel Anda, misalnya kerusakan papan sirkuit, atau bahkan lebih parah lagi, baterai dapat meledak dengan api, yaitu mengembang dan pecah, yang dapat menyebabkan bahaya kebakaran kecil. Saran saya adalah mengganti baterai sekarang juga.
Karena iFixit belum memiliki panduan khusus untuk ini, gunakan video seperti ini. Alih-alih menggunakan hot plate, Anda dapat menggunakan pengering rambut atau alat pemanas untuk melonggarkan lem pada penutup belakang. Buang baterai lama Anda dengan benar. Setelah baterai diganti dan semua kabel fleksibel diperiksa, Anda perlu mengevaluasi kembali ponsel Anda untuk melihat apakah dapat dinyalakan kembali. Beritahu kami hasilnya.
Saat Anda bekerja pada ponsel Anda, ambil banyak foto. Setelah selesai, gunakan foto-foto tersebut untuk membuat panduan untuk iFixit. Hal ini akan membantu orang lain yang memiliki perangkat dengan masalah yang sama. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargainya.
Perbaikan adalah Perang Melawan Entropi!
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 47
