Zum Hauptinhalt wechseln
Released in 2020, the Samsung W21 5G is a foldable phone that can turn into a full tablet. Identifiable by model SM-W2021.
Why won't my phone not charge
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
There are a number of reasons that your phone might not charge. Here are three things you can try, in order of easiest to most complicated:
  1. Make sure that the charging port is clean and free of debris. If is looks dirty, Try to clean it using this guide
# Ensure that your charger is working. The easiest way to do so is to see if it can charge another USB C device. If your charger cannot do so, replace the charger.
  1. If those steps don't work, see if you can replace the battery and/or the USB C port. The way to determine which one of these needs replacing is easy. Attempt to charge the phone with a wireless charger. If it charges wirelessly, then the USB C port needs replacing. If it does not charge wirelessly, then the battery needs replacing.
Unfortunately, there is not a specific guide on iFixit for your model of phone; however, you can look a similar tutorials, or take your phone to a repair shop/
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Maritza wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 36
