Zum Hauptinhalt wechseln
Repair guides, disassembly, and troubleshooting information for the Hyundai Accent GLS, first released in 2001. The fourth generation, designated by the RB model code, was sold in North America from 2012 to 2017 and offered as either a four-door sedan or five-door hatchback.
Why the alarm of check engine can appear
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @haithamabu34959
The check engine light is on telling you that there's a problem with the engine that needs your attention.
It will be gone once you find and fix the problem that has caused it to come on
The easiest way to find out what the problem is, is to get the OBDII port in the vehicle scanned with an appropriate scantool to see what DTC code (Diagnostic Troubleshooting Code) has been stored. The code tells you what the problem is.
If you're in the USA major auto parts retail stores e.g. AutoZone, PepBoys, O'Reilly Auto Parts etc, do this for free apparently.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
haitham abukasawi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 161
