Zum Hauptinhalt wechseln
Reparaturanleitungen, Informationen zur Demontage und zur Fehlerdiagnose für die elektrische Zahnbürste Oral-B Typ 3771. Identifizierbar an der Typnummer 3771.
order a replacement battery for my
How do I order the replacement battery for my type 3771 oral b toothbrush
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Click on the device page in the upper right corner of this page, then scroll down to Parts. Click on Batteries, then on the pane marked "49mm x 14mm Li-ion Toothbrush & Shaver Battery - with Solder Tags". From there, select whether you want the battery alone, or the "Fix Kit", which includes the battery and tools needed to install it. Note that these batteries are soldered in, so some soldering will be required and the kit does not include a soldering iron or solder.
Here's a shortcut to the page you want.
If you prefer to do your own shopping, the battery you need is 49mm long by 14mm in diameter. It's a 3.6V Lithium Ion battery, and you'll want one with solder tags so you're not soldering directly on the battery terminals unless you have a spot welder for batteries. I'm not sure what the original battery capacity is, but the replacement iFixit sells is rated at 740 mAh, so you'll want one around that value. A smaller value will still work, but it won't hold as much charge; the higher the number the longer it'll go between charges.
Unfortunately, iFixit doesn't have a guide for that repair, but the site toothbrushbattery.com has just what you need. After reviewing the guide, it does appear you'll need a decent amount of soldering skill to pull this one off.
Braun Oral-B Genius/Smart Type 3765 & 3771 Battery Replacement - ToothbrushBattery.com
Good luck and be sure to let us know how it all turns out for you!
Replace a dead or malfunctioning battery in various Braun Oral-B toothbrushes, including the Genius X, 10000, 9000, 8000, 7000, Smart 6000 and some Smart or Pro models. Bild
Produkt
$19.99
War diese Antwort hilfreich?
Bewertung 1
I think that this item may work.
Be sure to check the serial number though
Produkt
$19.99
Bewertung 1
Antwort hinzufügen
Joe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 21
Letzte 30 Tage: 111
Insgesamt: 684
