Zum Hauptinhalt wechseln
Angekündigt im Oktober 1999.
Why is there no startup chime on my iMac g3?
I have had my 1999 graphite iMac g3 for a while now, but I noticed a recurring issue. When I boot up my iMac, there is no start up chime. I first replaced the p-ram battery, still no startup chime. Checked the speakers on itunes, the speakers were fine. Is there a setting I do not know about?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
@powerpcuser what do you get when you boot up your iMac?
von
Does music or vids play with sound?
von
@oldturkey03 When I boot my Mac, It is the same as any other mac just without the chime.
von
@danj Yes, the speaker work fine in everything else except the boot up chime.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
OK, the Startup tone setting in the OS (firmware) needs to be reset, if it stopped working on its own then a PRAM reset should fix it, if the version of OS-X Apple disabled it presently installed there's a terminal command you can re-enable it. What is the OS-X version you have? Here's how to reset the PRAM How to reset NVRAM on a Mac if the AC power is disrupted even if the system is not on the PRAM battery may need replacing as well.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
power pc user wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 92
