Zum Hauptinhalt wechseln
Die Xbox Series S ist die aktuelle Konsole von Microsoft, die ohne Laufwerk auskommt. Sie wurde mit ihrem großen Bruder, der Xbox Series X, am 10. November 2020 veröffentlicht.
Why can't I see the screen?
I was gonna play games and check for updates when my screen remained black, no "no signal detected" no error or anything, just black. and when I turned it off and on, check for dust, and see if the hdmi was either loose or broken, nothing was not doing anything to let me see. and when I had my headset on, only the headset can pick up the sound, so I can't see or hear the game. can anyone help me?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi!
How is the HDMI port, still good? Did you tried other HDMI cables? Did you test on another TV? Could be the retimer.. can you share a picture regarding the HDMI port? Thanks!!
von
Einen Kommentar hinzufügen
1 Antwort
This could be a broken solder joint on the HDMI port or a failed in line component. I recommend sending in your xbox to have the HDMI port changed, as this is an especially difficult task for a first timer or someone not well equipped for the job.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Christopher Galindo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 97
