Why is my resmed airsense 10 pumping air iregular?
My resmed airsense 10 is pumping air in a different pattern then it should. When I breath out it pumps air in.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
I own the same unit, you might be up for a new face mask. Be assured it always pumps air out in a non-stop fashion. The diaphragm in it could be bad amazon a new one if your not supplied with one by your doctor. The machine only pumps air out at a near fixed rate, its also possible that the air pressure sensor is bad which "regulates" air flow is bad. unfortunately I've not seen a break down of this machine but I'd assume this is controlled by a locked microprocessor.
von
Einen Kommentar hinzufügen
