Zum Hauptinhalt wechseln
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
My PS3 Slim CECH-3004B has stopped reading discs after disassembly.
Hi,
Over the weekend I decided to disassemble and clean my PS3 Slim with isopropyl alcohol. At the same time I replaced both the thermal paste and the CMOS battery. After careful reassembly I turned the console on and saw a bit of white smoke coming out from under the Blu-Ray Drive (around the CMOS battery to be exact), although I didn't hear any bangs or pops from the console.
The main problem is that the PS3 has stopped reading discs, with no prior failure indicators. The console hadn't been opened before, so I presume any wrongdoing is my fault. I have tried rebuilding the file system via the safe mode menu and reconnecting the drive to no avail. How should I go about fixing it? Should I replace the laser/the entire Blu-Ray drive, or try some further diagnosis?
Thanks in advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi!
In your case I would replace the disk drive cable and see what happens. I doubt that it will work… most likely that something happened with the drive it’s PCB. The issue here is that you can’t replace that one as it is married with the motherboard…
You can try a new cable and see what happens. Otherwise it will be a disc-less console…
Can you let us know how that goes?
Thanks!
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
el_gato wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 107
