Zum Hauptinhalt wechseln
My GSD2100V70WW dishes washer won't drain after uses
When my GSD2100V70WW built-in dishwasher dishes washer was used it and it stopped draining water out and it's just sitting in the bottom
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @syrusmcgill
Could be a faulty drain solenoid.
Rather than just throw parts at the machine in an attempt to fix it, here's an article that describes where to find the mini manual (GE part # 31-4000225 Note: I couldn't find it online) in the machine or if it isn't there how you can get it for free.
The manual details the procedure for how to enter the diagnostic service mode for the dishwasher so that the various parts can be tested etc. If there is a problem detected then an error code will result telling you what the problem is.
If you find the problem and it's a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown for the part. Search online for the part number only, to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky there'll be videos showing how to remove/replace the part.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Is that how it sounded? lol, I will keep that in mind. Definitely not recommending replacing all of that!
von
Does it make any noises when it tries to drain? Motor sounds? gurgling? Often this is caused by a clog in the drain. But it can also be caused by a dead pump.
Bewertung 0
Antwort hinzufügen
Syrus Mcgill wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 106
