Zum Hauptinhalt wechseln
27" Display mit einer Auflösung von 2560 x 1440 Pixel und Thunderbolt & MagSafe Kabelbefestigungen
Can someone help identify this part?
Hey All!
Deep in the weeds with this THUNDERBOLT 27" display -I have no screen, and the thunderbolt connection not detected by an external computer, but power is getting to the logic board just fine. Tested the G, 12V, and 24V rails and power is fine on the logic board. When testing the smaller panel test points, fan, usb, etc. works great, but no power at the LCD power panel test points (Just to the left of the circled component in the pic attached). There should be 12v there according to the Technician's manual.
Ok, but there IS 12V right at the circled component on the one leg at the bottom, but 0 volts on either of the other two legs! So I suspect this part has failed.
Now the help! What is this part? Voltage divider or detector? It's labeled with either a "AM K" or "1 AM K" (K is sideways) although the 1 might just be a line indicating directionality? These components are all over the board and always gives voltage readings on all legs, so that's why I suspect this one is bad. Any super smart SMD folks know what this part is?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Thanks All,
I will swap it out and report back - might be nice to know if it works if you happen to lose voltage at that lcd power test point! Stay tuned...
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@iluvsa here is the 820 2997 PDF schematic only since board views are not available for your Thunderbolt display. The component shows a 1AM marking denotes that it is a MMBT3904G in a SOT23 package.
War diese Antwort hilfreich?
Bewertung 1
You'll want to go to this web site to grab the schematic drawings BadCaps - Thunderbolt Display
Bewertung 1
Antwort hinzufügen
Ryan Harrigan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 22
Insgesamt: 87
