I have a problem sometimes with WiFi, it shows
I have a problem with the WiFi sometimes, it shows portal keeps stopping, so what can I do
Ist dies eine gute Frage?
Just clarifying what you mean when you said "....it shows portal keeps stopping,.....".
Do you mean that the WiFi connection to a network is lost but the WiFi is still turned on in the phone or that the WiFi turns off in the phone?
If it's just that the WiFi connection to a network is lost, then it could be an antenna problem in the phone.
Try using the phone's WiFi as close as possible to your home network WiFi router e.g. <15cm and check if the phone detects, connects and maintains a stable connection to the network.
If it does check if the antenna in the phone is securely connected at both ends i.e. mainboard and sub board.
Here's a zoomed in image taken from Step.15 in the ifixit Samsung Galaxy A70 Display ersetzen guide that shows the WiFi antenna.
If the antenna is faulty, search online for GH39-02014A to find suppliers that suit you best. (supplier examples only)
(click on image)
War diese Antwort hilfreich?
Is it happening everywhere or select places? If phone is not able to sense Wi-fi in select places then it could be antenna problem.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 109
1 Kommentar
No,Acctully the problem is captive portal login keeps stopping ,that what I meant
von Mohamed Abdulhalim
