Zum Hauptinhalt wechseln
Diese Seite enthält Hintergrundinformationen, Identifizierungshilfen und technische Details zum Dell Latitude 5410 Laptop. Es handelt sich um ein silbergraues Laptop, dessen Modellnummer sich an der Unterseite des Geräts unter den Lüftungsschlitzen befindet.
Haw to configure network settings for less consumption of data
My machine consums a lot of data when hotspot
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
The Dell Latitude 5410 (typically running Windows 10 or 11) doesn't have unique network hardware settings that drastically change data consumption compared to standard Windows laptops. High data usage often comes from background processes like Windows Update, app sync (OneDrive, etc.), telemetry, automatic downloads, and cloud features—especially noticeable when using a mobile hotspot or limited data plan.
Here are the most effective ways to configure your network and system settings to significantly reduce data usage:
  1. Set Your Connection as Metered
  2. Monitor and Set a Data Limit
  3. Restrict Windows Update and Delivery Optimization
  4. Limit Background Apps and Other Data-Hungry Features
  5. Additional Quick Wins
If data usage remains high even after these changes (e.g., specific app or driver issue), check the Data usage breakdown for the culprit app or consider updating your Wi-Fi drivers via Dell SupportAssist or the Dell website.
War diese Antwort hilfreich?
Bewertung 0
You need to control your Applications!
Review what are auto launched as well as what are not active on your Desktop space. As an example you might have open tabs in your Web Browser which are constantly being refreshed. It could be a Cloud based file which is shared that you have open.
The computer and its OS are slaves to the Apps you have running, at best you might be able to get some data compression, but mostly this only works with file compression inflight not dialogs as they are not as bulky.
Bewertung 0
Antwort hinzufügen
Teneng Faith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 23
Insgesamt: 139
