Zum Hauptinhalt wechseln
Reparatur von LED-, Glühbirnen- und anderen tragbaren elektrischen Lichtquellen.
Tactical flashlight won't work with new batteries. Emitter, driver?
I have four Pro-4 tactical flashlights (two large, two small) that worked well for at least five years. Now they're dead and new batteries aren't the fix. Interiorly, in each, it's clear the emitter is (securely) wired to a driver. How do I determine what component has failed? Are the components replaceable? These flashlight are heavy, milled aluminum worth much more than their original ticket...it seems unthinkable to toss them.
I might add that, sadly, the small emitters weren't designed for easy replacement as they appear to be a permanent part of of a design-specific aluminum ring.
How might I proceed? Happy to provide flashlight ID, disassembly, and repair pics when/if pertinent. I can do basic soldering and my fixit persistence is a local legend.
I found the Pro-4 flashlights at Sam's back in the day. One can find them used on eBay, but it appears they're no longer manufactured. The original promotional copy included:
The Pro-4 Tactical Flashlight with COB Lantern is up to 40 times brighter than ordinary flashlights. It features, aircraft-grade aluminum construction, zoom-in and zoom-out functionality, and five light modes. It provides bright, reliable light in nearly any situation. Use for home, work, outdoors, and emergencies. The Pro-4 Tactical Flashlight with COB Lantern is one of the most powerful flashlights of its size on the market.
Manufacturer SKU:4974
Runnings SKU:70310076
  • Up to 200 Lumens
  • Bulb: T6
  • Batteries: 3 AAA Alkaline Batteries (included)
  • 5 Modes – High, Low, Strobe, Lantern, Red Flashing
  • Zoom Function: Spot to Flood
  • Retractable Wrist Strap
  • Aluminum Construction
  • Built-In COB Lantern
  • Magnetic Base
  • Weight: 129 grams (without batteries)
  • Size: 7.1” L Open; 6.6” L Closed x 1.42” Top D x 1.2” Bottom D
  • Water/Shock Resistant
  • 1 Year – No Questions Asked Warranty
Update (02/02/26)
Update (02/02/26)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Adding some pictures and the brand/model is very helpful! Also, are you using the same brand of batteries as you used before? Did the batteries work in another device? If these are the standard 18650 cells, there are plenty of counterfit/poor quality ones availabe on Amazon. If the flashlights worked well beforehand, it would be worthwhile testing another battery.
Once you add some pictures/model #s I'm happy to take a look.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Duracell has been my go to. A test with Amazon rechargeables was no go.
von
1. Identify the Switch Type
Is your flashlight using a mechanical 'clicky' switch (usually located at the tail cap) or an electronic 'touch' switch (usually a soft-press button on the side)? Since you mentioned a Driver, it is very likely they use an electronic touch switch, which integrates differently into the circuit. Knowing this will help us determine how to bypass it for testing.
2. Isolate the Failure (Driver vs. Emitter)
The 'Emitter' is the LED itself. To find out which component has failed, you need to check for output from the Driver:
  • ​Use a multimeter to measure the DC Voltage at the two solder points on the Emitter (LED board) where the wires from the Driver are connected.
  • If you see voltage (around 3V–4V) but no light: The Emitter (LED) is burnt out and needs replacement.
  • If there is 0V: The issue is either a failed Driver board or a faulty switch signal.
​Please let me know the switch type or provide a photo of the internals, and we can take the next step together!"
Bewertung 1
4 Kommentare:
Firstly, check the driver card is receiving the voltage from the battery pack.
I still don't see the switch in the images you provided.Since it has a driver card that can switch between 5 functions, I suspect it uses a tactile switch.Typically, these switches have either 2 or 4 pins. While the batteries are installed, try shorting the wires or pins connected to the switch using a pair of tweezers.If the light turns on, then you just need to replace that switch.
If the light still doesn't turn on, you should measure the Voltage (V) at the two wires connecting the driver card to the LED.If there is no voltage output, the driver card is faulty. You can order replacement cards from e-commerce sites like AliExpress or Amazon.
To check if the LED itself is still good, disconnect the wires between the driver card and the LED, then apply voltage directly from the battery pack to the LED.If it flickers or lights up even for a moment, the LED is fine. Good Luck With the repair.
von
A multimeter shows the driver card is NOT getting juice. The switch is likely a classic push button type, with a spring, it's off with one click and on with another. Just as the switch, the LED is cemented into its aluminum housing. (I didn't pick a very cooperative repair candidate.)
Still, with the info you've provided and the multimeter data, I'll install a new driver card. It'll take a bit, but I'll be back with an update:)
von
And THANK YOU Phone Kaung! Your instructions are really clear and your knowledge base is IMPRESSIVE.
von
Based on what you've described, the issue might not be a faulty driver card. It is more likely a connection failure between the battery and the driver card, or a problem with the switch itself.
You need to ensure that voltage (V) is actually reaching the driver card first. If the battery pack's pins or connection points are corroded, use some sandpaper to clean them up.
Fix the connection to get voltage to the driver first. Only then can you accurately determine if the driver card is actually defective.
von
Antwort hinzufügen
Reduviidae wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 155
