Zum Hauptinhalt wechseln
Der 5-türige Explorer und sein Begleitmodell, der Mercury Mountaineer, wurden für das Modelljahr 2002 komplett überarbeitet und erhielten ein ähnliches Erscheinungsbild wie sein großer Bruder, der Ford Expedition.
What might be cost for car that's list reverse
Putting the car in Reverse . It wont go help
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@roseprose that really will depend on what the cause for this is. A common issue for the no Reverse is a broken reverse band or failed servo. That would require removal and repair of the transmission and will therefore be one of the most/most expensive repairs. repair cost for that is somewhere around the $1500-$2000 range. Of course, that will depend on where you are and what your normal Shop rate is.
Before doing anything, check the simpler things. Like:
  • Check Fluid Level: Make sure that you have enough ATF and that it does not look/smell burned etc. Ensure the fluid is not low or burnt.
  • Inspect Linkage: Check that the shifter linkage moves properly and that it actually engages your Reverse gear.
  • Scan for Codes: Have your Explorer's OBDII scanned and see what codes (if any) it gives you. Let us know.
  • Check Range Sensor: The transmission neutral safety switch could be faulty.
If you let us know what exact year and engine size your Explorer is, we could possibly give you more points to check as well as provide you with some guidance on how to check those.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Rose prose wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 235
