Zum Hauptinhalt wechseln
Informationen und Reparaturanleitungen für MacBook Pro Modelle mit 13 Zoll Displays.
9729 Fragen Alle anzeigen
Frage geschlossen
after disassembling my mbp,bluetooth and camera stop working
after disassembling my mbp,bluetooth and camera stop working。i‘m from china,so,my english is poor,forgive me。hope you can understand what i say and answer my question,thank you~!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Which model of Macbook Pro do you have?
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Try to do a PRAM reset. Switch off your laptop. Then press power button and immediately hold option+command+p+r buttons together before the apple logo comes up. You will hear the chime sound. Keep holding the buttons and then release until you hear the second chime sound. It should reset the PRAM and hopefully will fix the bluetooth and camera issue.
von
Good course of action. I'd add, to gauge what Macbook Pro exactly is, that our user should go into "System Profiler" and provide the iFixit Community with the last three letters and numbers of the Serial Number.
Also, an SMC reset, different if the Macbook has or hasn't a removable battery, is in order.
von
I have had exactly the same issue. However this did not fix the issue. Do both of these components attach using the same connector? I suspect i might have damaged the connector in some way with a bodged attempt at refitting it.
How likely is this. The connector looks very fragile.
Chris
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 554
