It’s frustrating when a classic piece of tech like the Sony MZ-S1 goes silent, especially since those "Sports" models were built to be tanks. Since you’re comfortable with disassembly, you’ve already cleared the biggest hurdle.
When a MiniDisc player refuses to power on via both battery and DC cable, the issue is usually an interruption in the power delivery circuit. Here is a troubleshooting roadmap for when you get inside:
Even if there is no "visible damage," microscopic oxidation or a slight leak from a years-old AA battery can create a high-resistance layer on the contacts.
- The Fix: Use a cotton swab with 90% Isopropyl Alcohol to scrub the internal battery contacts. If you see any green or white crust, use a tiny bit of white vinegar to neutralize the alkaline leak, then follow up with alcohol.
The MZ-S1 uses a switching jack. When you plug in the power cable, a physical leaf switch inside the jack disconnects the battery to prevent charging it.
- The Problem: These leaf switches often get stuck or oxidized in the "closed" position, tricking the device into thinking a cable is plugged in (cutting off the battery) or vice versa.
- The Fix: Spray a small amount of DeoxIT or electronic contact cleaner into the DC jack and insert/remove the power plug rapidly 10–20 times to clean the internal switch.
Sony boards from this era occasionally suffer from cold solder joints near the power input.
- The Fix: Once the board is out, inspect the pins where the DC jack and battery terminals meet the PCB. If the solder looks dull or has a tiny ring around the pin, "reflow" it by touching it with a soldering iron and a tiny bit of fresh solder.
MiniDisc players often have a tiny surface-mount (SMD) fuse near the power intake (often labeled F1 or TH1 on the board).
- The Fix: Use a multimeter in Continuity Mode. If the fuse doesn't "beep," it's blown and needs to be bridged or replaced.
It sounds simple, but double-check that the physical HOLD switch isn't stuck halfway. If the device thinks HOLD is engaged, it won't respond to the power/play buttons. Sometimes the plastic slider snaps off internally while the electronic switch stays in the "ON" position.
Would you like me to help you find the specific service manual or circuit board layout for the MZ-S1 so you can locate the fuse?
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
