Zum Hauptinhalt wechseln
Repair information for Microsoft's Surface Pro 9, released on October 25, 2022.
Disassembled my surface, how do I fix my screen?
I was tinkering with my surface, and then put everything back in place, but just as I turned it on after putting the screen back it has large digital tears. My screen doesn’t seem to have any physical cracks or damage on both the front and back. What do I do?
Also, I recently ordered the adhesive for it so I can glue it back together, I’m waiting for it to arrive
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@jaegernigh53669 not sure what you mean by "tinkering with my surface" but what you do have is a bad LCD. The white stripe is clearly a disconnect of the COF from the LCD. Also, the rest of your screen seems to have plenty of anomalies as well. This looks like you have a cracked screen
Ultimately, this looks like you will need to replace the LCD.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hi @jaegernigh53669
To add to the answer above, here's the service manual for the laptop. Go to p.35 (of 88 pdf) to view the procedure to remove/replace the display assembly.
von
Antwort hinzufügen
Jäger Nightrunner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 38
