Sensi ST55 thermostat temperature sensor inaccurate/broken
okay this is a longshot. but in the Interest of making things better. i figured i might as well ask. what am i out?
i have a 10 yr old 'smart' thermostat. with a life expectancy of 10 yrs... well almost to the day... it just stopped reading temperature accurately or at all? it was displaying 69° - 72° even when i took ot outside in 10° weather...
i have minimal skill, i have done some soldering in the past. reattached USB micro ports and other fiddly things. but this might be beyond my ability...
i was hoping to offer my dead thermostat for the cause... if someone else is willing to reverse engineer it.
otherwise I have pictures of the back of the motherboard and am willing to take it apart more. to at least identify the temperature sensor or w/e failed. because it seems like it was made to fail.. and we can't have that.
any suggestions or do you need more info from me?
thanks!
Update (02/02/26)
Update (02/03/26)
I think I might have it, I was on the YouTube just now and watching an off the wall vid recommended by my feed... and something crazy happened at the 11 minute mark...
https://youtu.be/-wEKOhVZ0NM?t=660
there it is is! that's what they look like! and and they are apparently only like $3.00 USD.
and I've found an eerily similar item on the mobo for the thermostat. (circled in red -- in picture below)
[ also note the arrow pointing out venting in the case, as I believe that is there to help facilitate an accurate reading of temp/humidity.]
Update (02/03/26)
I do happen to have another image that I took of the PCB, its not great either, but a little better. (I used flash)
with it we can decipher that what I assume to be the temp sensor says: "ANDU"
not sure if that's helpful..
either way here's this image, until I can get home and take some better ones.
Update (02/04/26)
so many pictures :D
Ist dies eine gute Frage?
This is likely a failure of the thermal sensor inside your smart thermostat. If you can provide a clear photo of the circuit board, I believe I can help you identify the specific component. Replacing that faulty sensor should fix the temperature reading issue and bring it back to life.
von Phone Kaung Teilen
i figured out how to attach pictures!
von Luke Waletzki Teilen
I'm still uncertain about the sensor's location from the front view. If it's convenient, could you please show the back side of the circuit board? That should give us a much clearer answer.
I will get better pictures yes,
we'll need to be able to see which type it is if we want to have a drop in replacement.
as there are so many to choose from:
https://www.digikey.com/en/products/filt...
https://www.mouser.com/c/sensors/environ...
o.O
@phonekaung if you require a more specific image. let me know, I tired to get get good ones of the whole thing.
Thanks!
1 weiteren Kommentar anzeigen
