Zum Hauptinhalt wechseln
Reparaturanleitungen, Informationen zur Demontage und Fehlerdiagnose für das Apple iPad der 9. Generation mit WLAN, erhältlich mit 64 oder 256 GB Speicherplatz. Veröffentlicht im September 2021. Identifiziert durch die Modellnummer A2602.
iPad 9th's SSD repair PopQuiz question
Hey, there fixer, here's a question that I want you guys at the iFixit community to answer!
So I used to have an iPad here at the workshop, but it got sent over t Apple.
But, it was only 64GB, How do i upgrade the physical SSD?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Well... this won't be easy as you need to fully remove the logic board to then take the shield lid off to get to the NAND (flash chip) here's the guide iPad 9 Logic Board tauschen. And here's a view of the board (I've highlighted it in Yellow)
You need a very steady hand to heat up the chip using a hot air rework station to soften the under fill and then carefully get the chips soldier pads to release without damaging them.
But you just can't slide in any chip it needs to have the correct image file installed and each different sized chip has a different one and you also need to edit it with your systems details. Given the amount of work, skill and tool costs it might be just better to replace the board with the one that offers the needed storage. Or, just get a replacement iPad as the cost may not be worthwhile or will you find a good board in the size you want.
Lastly, we still have a gremlin to deal with, as you need to replace the TouchID the board is mated with and if you buy a board it needs to be iCloud clean.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Okay, that was just a pop quiz, I already bought my new iPad.
von
@ahmadawick - Do make the effort to accept one of the answers as answering the question.
von
Hilfreichste Antwort
you need a nand programmer then you will need to remove the nand from the logic board and copy the data then you will need to write that data to the higher capacity nand and solder it to the logic board
Bewertung 1
1 Kommentar:
@tech_ni I already bought my new iPad. That was just a pop quiz and you win
von
Antwort hinzufügen
redratchet21 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 46
Insgesamt: 280
