Zum Hauptinhalt wechseln
Das Galaxy S7 Edge ist die Variante mit gekrümmtem Bildschirm von Samsungs 2016 Flaggschiff-Smartphone, dem Galaxy S7. Angekündigt im Februar 2016 und am 11. März 2016 veröffentlicht. Modell SM-G935.
boot loop issue and not showing up in odin
Got this S7 Edge from a discard pile at work. trying to fix it. It doesn't seem to hold a charge, but I can't tell. It powers on when plugged into the computer, and after a while, it attempts to enter recovery mode. When installing the android update blue screen after two seconds it immediately shuts down and goes back to the charging screen. When plugged into odin, it does not show in at all.
Update (02/05/26)
Im going to try a new battery. I feel like that could be the issue since it does not like powering on after being unplugged. but will update this thread
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
can be re-flash by software ?
von
Einen Kommentar hinzufügen
1 Antwort
Update. So it turns out the phone was in poor condition. It took a full charge wirelesly to boot into android 7, and it looks like it got past the recovery screen after 6 hours when It charged up enough. It looks like it has a bad port and a major battery issue. Accubattery says the capacity was 1270 of the original 3600mah. I can't even back up since the port may not work
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Hi @fegelein3290,
Try replacing the charge port flex they're not that expensive
Here's a link to the service manual that you can use online (need to sign in to download though) if you fancy a bit of board level testing that is
Cheers
von
Antwort hinzufügen
Brayden S wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 26
Insgesamt: 43
