Zum Hauptinhalt wechseln
Repair and disassembly guides for electronic keyboards.
Casio WK3700 DSP not working
I have an old Casio WK3700 electronic piano/keyboard.
When powered on in Grand Piano mode 000 it works fine. If I try any other mode the DSP button lights up and it emits a distorted thrumming sound and eventually powers off.
I assume the DSP circuitry is stuffed. Video
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @wayne51244
If you haven't already done so try to reset the keyboard back to default and check if that fixes it.
  • Remove the batteries from the keyboard (if inserted) and disconnect the AC adapter from the keyboard
  • Press and hold the Power button operated for about 20 seconds and then release it.
  • Reinsert the batteries (or reconnect the AC adapter), and turn on the keyboard
  • Use the Transpose/Function button to perform a system reset.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks for this. I'm gunna look pretty silly if it works.
von
I have same issue and hoping to replace the IC4
Bewertung 0
Antwort hinzufügen
wayne wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 58
