Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
Frage geschlossen
Upper right corner doesn't respond + glue doesn't stick
I just repaired an iPod Touch 4G and everything went great apart from two things:
  • The upper right corner doesn't seem to respond on touches
  • When reassembling, the front panel won't stick together. I used 3M tape, but it doesn't seem strong enough to keep both parts together
Any suggestions/tips?
Thx!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds like the screen you used has a defective digitizer.
When I repair these iPods I usually use a head gun to lightly warm the outer edges of the new glass once it is installed to "melt" the adhesive and then I put the iPod on a flat surface on a microfiber towel and then put a couple of heavy books on top. It always gives it a better stick!
Also, check to see if that top corner is dented or bent. That can always make a difference too
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 547
