Zum Hauptinhalt wechseln
Der größere von Apples MacBook Air Laptops mit Doppelmikrofon und 802.11ac Wi-Fi Konnektivität.
Logic Board Compatibility MacBook Air A1466
Hi, I have a mid-2013 Macbook Air A1466 with the lower powered processor (i5 1.3Ghz) and only 4GB of RAM. The Macbook is in good order but I would like to upgrade to 8GB of RAM by swapping out the logic board.
I'm seeing conflicting accounts of logic board compatibility across this model range. Some sellers on eBay suggest that you can use any A1466 board on any A1466 machine. Another says that the board nos. have to match. Mine is an 820-3437-A.
Does anyone know which is correct please?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
A1466 - 2012 Are Unique (Shorter Web Cam Cable & a longer webcam module that will not lay flat in the case (Unless you grind away the screw hole)..
2013-2017 Are fully interchangeable,I did it many times.
War diese Antwort hilfreich?
Bewertung 2
Most of them are interchangeable however the 2017 has different connector for the webcam.
Bewertung 0
1 Kommentar:
It is the 2012 model that has the shorter webcam cable that connects to the I/O board. 2013-17 models the webcam connects to the logic board.
von
Antwort hinzufügen
Roger H wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 115
