Zum Hauptinhalt wechseln
This is the fifth generation of Honda CR-V.
Altanator working but battery lights still on
Why is the car alternator working but battery lights still on…..?
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
@diamondakabutu what voltage do you get on your battery when your Honda is running? It is possible that the light is on because the battery isn't receiving enough voltage to charge it properly
von
Change battery.. 100%
von
@matthewccleary I disagree; without more diagnosis you can't say for sure it's the battery; it could be the alternator, the voltage regulator (usually built into the alternator these days), the battery or a wiring issue.
von
Einen Kommentar hinzufügen
1 Antwort
Need more information. Could be battery, could be batter sensor, wiring between alternator and battery... what is battery voltage with key on engine off and what is it with key on engine running? You should have roughly 12.6 volts off and roughly 14.7 running with all accessories off. Try wiggling wires (carefully) while its running and see if it stumbles or shuts down, or if light goes off. Does it ever stall out on its own
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Diamond Akabutu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 91
