Der Samsung RF24FSEDB ist ein 665-Liter-French-Door-Kühlschrank mit flächenbündigem Design, einer fingerabdruckresistenten Oberfläche, Twin-Cooling-Plus-System mit getrennten Verdampfern, Power-Freeze- und Power-Cool-Funktionen sowie LED-Beleuchtung.
our freezer works fine, but the back of the fridge constantly freezes up. you can see ice coming through the vents in the back and you can hear the fan trying to turn to disperse cool air. Normally, we turn off the fridge for a night and let everything thaw out until the morning, but we would like to resolve the problem of the fridge icing up completly.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Sounds like there's a problem with the auto defrost in the refrigerator and the ice is not being melted during the auto defrost cycle and is building up.
This could be due to a faulty defrost heater, a faulty defrost thermostat, a blocked drain leading from under the evaporator unit to the evaporator drain pan under the compartments or worst case a faulty control board.
Go to p.70 (71 of 130 pdf) in the manual to see how to initiate the Self-diagnostic function during normal operation procedure and check what error codes (if any) are being displayed during the test.
The error codes, the components and how to check the components are shown on p.71→p.72.
The manual also describes how to remove/replace the individual parts, has troubleshooting flowcharts and schematics as well.
If you find the problem and it's a faulty part that needs replacing, here's a link to the parts list that is useful.
There are 41 model variants beginning with RF24FSEDB*. To ensure that you get the correct part, select your particular model from the list, locate the wanted part in the parts list for your model that appears and note the manufacturer's part number that is shown with the part.
Search online for the manufacturer's part number only, to find suppliers that suit you best
