Zum Hauptinhalt wechseln
Serviceanleitungen und Supportdokumentationen für Philips Respironics CPAP Maschinen.
Relentless reboots, but runs fine once started.
Worked fine originally after receiving donated used unit. After a few months, pushing the start button would beep, display logo, display FW version, display flow rate, spin up the blower, then go dark and start the cycle over.
Eventually, the blower stays on and it runs through my sleep cycle like nothing ever happened. This normal state might be reached after 20 restarts. Also, after some random restart count it will stay off, requiring a replug power-up to begin the restart cycle anew, up to three replugs and about 20min being a worst case. Best case it fires up after about 10 restarts. I just realized I've never checked the display before a replug so I'll do that tonight. I checked, it goes blank when it's all beeped out.
All functions, settings, and input buttons work as expected after running, including the humidifier. No leaks or bad gaskets, blower spins freely. About to replace PCA button battery but the old one had good voltage. Contact cleaner used when resetting every jack. Power supply good. Filters clean. I'll be rechecking all of these things one more time plus a picky board inspection, but I don't expect to find a problem at component level.
I can't imagine what kind of consistent, repeatable error could exist with no fault found. It behaves as if some sensor feedback is telling the algorithm that it can't run or start. Considering getting a serial adapter module and downloading the tech software but I have never seen an error code on the display.
Subjectively, 3 things I find interesting are:
1) the restart blower puff seems to gain volume and power up to the running state; if it dwindles or remains lame it's likely restart attempts will stop until a replug
2) dial digit 4 is slightly dim, but lights as expected
3) I checked the button battery voltage in situ, and it crept upwards. I've never seen this before but some reading tells me their may be an intentional capacitor storage, maybe to kick start the blower or something.
I could talk about this all night, given that a new machine will run me $1400CDN.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Based on the symptoms you've described, I suspect a capacitor error.
You might think there's no problem at the component level because everything looks fine visually, but over time, capacitors tend to lose their capacitance (µF value).
This most commonly happens with the main capacitors. I suggest you carefully inspect and test them, as this behaves like a voltage stability issue.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
i would agree with phone kaung - i would also mention that the Philips CPAPs had an issue re dispensing a toxic material into the air you are breathing. You might want to check that out, especially since it is a donated device. Have u checked with insurance. My Resmed cpap cost me 20% of retail via insurance.
von Teilen
I'll dig into this Kaung, soon. My device fell outside the recall scope. Possible insurance chance approaching, but it'll be a couple of months before I learn the details. It would be awesome if I just need to replace an electrolytic to be back in business.
von Teilen
Antwort hinzufügen
Unook of the North wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 50
Insgesamt: 133
