Zum Hauptinhalt wechseln
Acer Nitro 5 AN515-58 is the 2022 release of the Acer Nitro 5 series. This guide should be compatible for all the Acer Nitro 5 AN515-58 variant.
Lower part of my screen has these lines that are vibrating up and down
There are lines that are vibrating in the lower part of my screen
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
@sar75456 we will have to see what this all looks like. Post some pictures/short video of what your screen shows with your question. Bilder zu einer vorhandenen Frage hinzufügen
von
Einen Kommentar hinzufügen
2 Antworten
Well outdated drivers, incorrect refresh rates, or a failing panel (LCD/OLED) are most of the main reason for this kind of issue so i will suggest you to check for these.
War diese Antwort hilfreich?
Bewertung 0
Vibrating horizontal lines on the lower part of your screen usually indicate a display hardware issue. First, connect the laptop to an external monitor. If the external display looks normal, the problem is likely the internal LCD panel or display cable. Slight pressure, drops, or hinge wear can loosen or damage the ribbon cable. Try adjusting the screen angle to see if the lines change. If the issue appears on both screens, update or reinstall your graphics driver. Persistent lines typically mean a failing LCD panel, which requires screen replacement rather than software repair.
Bewertung 0
Antwort hinzufügen
Sar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 114
