Zum Hauptinhalt wechseln
The NVMe has broken, how do I fix that
Six months ago, I became dissatisfied with using Lubuntu and decided to transition to Arch Linux. I had not yet fully verified all aspects of the new operating system; upon initiating it and removing Lubuntu, I attempted to partition the storage for Arch Linux. During this process, the laptop experienced a failure, resulting in persistent I/O errors. As a result, I discovered that the operating system had been lost, and the NVMe M.2 drive had become malfunctioning. I am withholding this information from my mother, fearing disciplinary actions, and she has not yet become aware of the issue. Currently, I am thirteen years old and am seeking guidance on how to resolve this problem.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
As a last resort, I would try to secure erase the SSD -- sometimes that brings them back from the dead. It's often ineffective or short term, but it DOES work if the errors aren't related due to bad flash. You can check the health this way: SSD- und eMMC-Diagnose und -Löschung – Debian-basierte Distributionen, Parted Magic Legacy- und 2026+-Versionen -- the tool I used is paid, but you can find Parted Magic on archive.org - look for the newest version available by month and year. If you want the latest version, you'll need to find a way to get hold of a prepaid debit card. This might have it baked into the BIOS being a "business" PC but Vostros tend to be rebadged Inspirons. But for the business PCs like the Latitude, those seem to be consistent with 8th gen+ Intel/Ryzen 4000+.
Consumer PCs and BIOSes are a gamble - I have even noticed that on Ryzen 5000 notebooks from Dell consumer, some also do not have it available! The GUI UEFI Dells usually do regardless, but text based is a wildcard :-(.
SSDs crap out all the time, especially with heavy write amplification and heavy workloads, or just bad luck - I have seen it with the cheap DRAMless "client SSDs" from SKHynix with the 2230 parts where they run hot for years and fail. Dell loves to use those, and they have a less than stellar reputation compared to the 2280 drives. I have had better luck with the PC711 even if the AMD controller and PC711 creates a DCP_WATCHDOG crash event with Win11 25H2 on a USB2 drive unless you disable all of the power management features. I don't suggest the PC711 2280 because it has notoriously bad firmware (sleep state issues), but it tends to be tolerable whereas the 2230 drives die in 7-8 years without fail.
Other drives like the Intel 670p tend to take it better, I have one of those in my former Best Buy demo PC I got when it was ~18 months old when I got it (with the C0 13th gen i5) with 9% wear but heavy writing abuse. It works fine (albeit as soon as this NAND shortage ends, it's getting a new SSD; but not a pricey one given it's a potential dud just in case because the CPU warranty extension will be... complicated). I would explain that to your mom in a way that makes sense to her.
If it makes you feel better when I was still in high school, my parents forced a low spec Celeron 900 Compaq on me with an ultimatum (ignoring used>new wins at the low end of the spectrum) and I could do better with an E6400 or some other Core 2 laptop from that time, albeit maybe needing a new hard drive early on.
In addition to that, the things I did to that laptop behind their back would have potentially led to being treated like a criminal or grounded, just upgrading the RAM was at risk of being treated like a criminal or grounded. IT NEEDED IT because W7 did not do well on 2GB, you needed 4GB+ back then! I also broke the power flex clip and somehow got it back on without them ever knowing. It died due to a bad USB board shorting anything it touches which was a known issue with that PCB. Even with that known issue, I treated it horribly because it was a pile of crap from day one.
Here is the SM: https://www.dell.com/support/manuals/en-... -- get a 512GB or 1TB SSD, 256GB is useless these days. It's not hard on yours, but the closest SM I found is for the 3400. Look for an SSD here: https://www.bestbuy.com/site/searchpage....
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@nick replacing the corrupted OS would not have any impact on this issue?
von Teilen
Persistent I/O errors during partitioning usually indicate NVMe failure, not just a corrupted OS. First, create a bootable Linux USB (Ubuntu or Arch) and boot from it. Open terminal and run sudo smartctl -a /dev/nvme0n1 (install smartmontools if needed) to check drive health. If SMART shows critical warnings, the NVMe is physically failing and must be replaced. Also test with dmesg | grep -i nvme for hardware errors. If errors persist, reinstalling won’t help. NVMe drives are replaceable in most laptops—check your model. Tell your mother honestly; hardware failures happen and aren’t punishment-worthy. Replacement is usually straightforward and affordable.
Bewertung 0
Antwort hinzufügen
Tùng Lâm Trần Nguyễn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 44
Insgesamt: 299
