Zum Hauptinhalt wechseln
Informationen zu Reparatur, Demontage und Fehlerdiagnose für das Motorola Moto G Stylus 5G (2024), ein 2024 veröffentlichtes Smartphone von Motorola.
Which basic tools should I buy to be able to do the screen replacement
Id like to know which tools should I absolutely get to do replace the screen (Motorola g stylus 5G 2024, a frame is included). I never did this type of repair before. Is there a kit which includes all that is necessary that someone could recommend?
Thanks
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
@leah45403 according to the service manual these are the tools required to disassemble your phone:
Now, you do know you will not need all of those. Get the Allen wrench, the PH screwdrivers, some tweezers and the Shim as opening tools. You will need a heat source to loosen any adhesive, a good hair dryer or a heat gun (better) will work. Something like this kit Pro Tech Go Toolkit will definitely be a good investment.
You can download the service manual from this page Motorola Moto G Stylus 5G (2024) under the Documents Tab. Use something like this video plus the manual to replace the display.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Grab, Go, Fix! We created a bite-sized version of our best-selling Pro Tech® Toolkit, featuring the 32-bit Moray Driver Kit and our most essential repair tools. Bild
Produkt
Pro Tech Go Toolkit
$49.95
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Leah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 241
