Zum Hauptinhalt wechseln
My phone is connected to charger but not increasing battery
My phone is connected to charger but battery is not increasing
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@aslamraja First you want to check your power supply and the charging cable. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the connector on your phone. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc. use a few puffs of air to clean it out.
If none of this works, it is best to get an ammeter and see if your phone draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. The other issue could be your charging board (daughter board). Personally, I would replace the battery and the charging board since the phone has to be opened up for either one of those. Prices are low enough to justify doing both at the same time. The charging board as well as the battery are readily available at many places.
Since iFixit does not yet have a specific guide for that, use something like this video to work on it.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Aslam Raja wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 68
Insgesamt: 335
