Zum Hauptinhalt wechseln
My phone is cracked on the screen what will I do
My phone is cracked on the screen how can I fix it
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
You'll need to replace the display assembly, which consists of the LCD, touch screen and front glass. While it is possible to replace just the front glass, to do so properly requires a vacuum chamber, a UV chamber and a vacuum table, so it's not practical for us home users to do for ourselves.
The screen replacement procedure is fairly standard on your phone; remove the back cover, unscrew the midframe cover and remove the battery. Then you separate the old display from the frame, clean off the old adhesive and glue on a new screen. This video shows you step by step how to do that.
Huawei Y9 Prime 2019 / Y9s Display Replacement Guide (STK-L21, STK-LX3) - YouTube
Good luck, and let us know how it turns out!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Desmond wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 50
