Zum Hauptinhalt wechseln
Das Asus X515 ist eine Serie von Einsteiger-Laptops, die 2020 herausgebracht wurde.
Are there any guides for how to replace a broken screen?
My computer's screen broke.
I was wondering if there were any guides on how to replace the screen.
If not, does anyone know which Asus laptops would be similar enough to follow it's guide instead?
Laptops are expensive and I'd rather not buy a new one, though I do know that they make them almost impossible to repair :/
VivoBook_ASUSLaptop X515EA_F1500EA
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Here is a link to the X552 that should be fairly similar: ASUS X552LAV-BBI5N08 Display austauschen
Happy Fixing
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Hopefully this guide will get you there, Emily.
I might point out that in many cases you don't actually have to remove the display assembly from the main case of the laptop; it depends on how the hinge covers are made.
If that's the case, you could skip all of the initial steps and start at Step 9 instead. I'd suggest trying that; if you can get the bezel off at that point then you're all set; unscrew the LCD, flip it down and unplug it and there you go. Otherwise just go back and start at the beginning.
von
Antwort hinzufügen
Emily wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 185
