Why is my Pathfinder shaking while in park
I put it in park and it shakes like it wants to die out and I can't find the problem
Ist dies eine gute Frage?
I had the same issue. check obd II codes for a misfire if so first take off engine cover by the 2 10mm bolts one in the middle one on the front then remove the air box (2 10mm bolt I belive) (may have to do this before engine cover) then make sure all ignition coils are plugged in if not check for any broken/failed ones by either unpluging when the engine is running you will be able to tell by it starting to chug or vibrate/shake more or remove the 10mm bolt for each ignition coil to check physically broken and replace (if front 3 cylinders) if it’s not fixed by that you will need to remove the intake manifold (I have not had to do this yet so I am uneducated on that.
I’d be willing to troubleshoot further
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 30
Insgesamt: 153
@eloyrubio does it only do that when it is in park or does it do that in Neutral as well? It sounds like you are saying that it does not idle well and that the RPM are going down. What RPM does it show you and how does it idle at all times? What have you already checked? Does the service engine light turn on? Hv you scanned the OBDII already? Any error codes? What exact year and what exact engine size is your Pathfinder.
von oldturkey03 Teilen
