Zum Hauptinhalt wechseln
1987 Honda Elite CH150 Roller. Manche nennen ihn Honda Spacey.
Why won’t it start even with gas direct to carborator
How come when I bypass everything and hook battery direct to starter,even with gas in carborator still no start
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
Como montar o cabeçote da vareta 2001
von Teilen
@dalmir have you downloaded the service manual from my answer. It show you how to work on that.
@dalmir, já descarregaste o manual de manutenção da minha resposta? Lá está explicado como resolver isso.
von Teilen
Einen Kommentar hinzufügen
1 Antwort
@geestatus by doing this "hook battery direct to starter" you are bypassing your ignition circuit as well as everything else. All you are getting that way, is your starter to run but the ignition circuit for the engine will not work.
What you can try to do, is to connect your battery the way it should be on your scooter. Then turn on the ignition. Now you can use a pair of booster cables, or similar, and try to engage your starter. Make sure that your scooter is not in gear etc. It will help if you can tell us what the issues with your Scooter are and why you are trying to do what you are doing.
In the meantime here is the Honda CH150 Service Manual that might help you with your repair
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Gee Status wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 33
Insgesamt: 423
