Zum Hauptinhalt wechseln
My HomePod won’t power on
My HomePod quit working and now won’t power on
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Did you try a different power outlet to see if it failed? If you did and the power cord and plug are not damaged it's likely the power supply failed internally.. here's the guide to get to the power supply which you can see in Steps 18 & 19 HomePod auseinander bauen
Depending when you bought it and if you took out AppleCare on it it might be better letting Apple repair it as getting parts is a sizable hurdle for the HomePod as there's two versions and they are different internally.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jason Cortez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 75
Insgesamt: 435
