Zum Hauptinhalt wechseln
Modell A2159, EMC 3301. Eine Neuauflage des Einstiegsmodells des MacBook Pro. Erhältlich in Silver und Space Gray. Erschienen im Juli 2019.
MacBook Pro 13 headless lower plate peeling off
I make it Headless and use it, and there is no problem. But the lower plate has quite a lot of lifting, so what should I do?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
It looks like the bottom cover casing isn't even screwed down? You have to put it all back together as though it still had he full display assembly (Minus the display assembly) but obviously keeping the antenna and clutch cover to have WiFi access.
This video from a 2019 15" should be a similar pocess.
MacBook Pro (13 Zoll, 2019, 2 Thunderbolt Ports) Displayeinheit austauschen
War diese Antwort hilfreich?
Bewertung 0
Sometimes we exceed what is practical, Apple engineers designed the system with the idea of the display frame as part of its rigidity structure so when you took it away the back side of the uppercase can't leverage it to support its self!
I've seen this a few times where people took the display off trying to overcome the failed display so the system could still be used. Over time the uppercase fatigues cracking and/or causing the logic board to flex which in turn creates a failure within it.
But the worst of it is while the system will run it wouldn't do what it can performance wise! You see Apples SMC logic senses the loss of the display and goes into CPU Safe Mode as the Intel chips tend to overheat! So the CPU clocking is reduced and the cooling fan is pushed to the higher RPM's
So while you gained access to the keyboard and trackpad you will wear-out your system a lot quicker than just using it in Clamshell Mode with the display folded down and using a BT/USB keyboard and mouse! And lastly when needed get the systems full performance!
Bewertung 0
Antwort hinzufügen
insaengjotgottae wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 30
Insgesamt: 93
