Zum Hauptinhalt wechseln
How can I reduce the rpm of my grinder?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
5 Kommentare
Hi @arsenbongat
What is the make and model number of the grinder?
von
Something like a China made
von
@arsenbongat why do you want to do that? What is your plan for this?
von
@arsenbongat
Would need to know whether it was battery powered or mains powered. Knowing the make and model number would be more helpful
"China made" doesn't tell us much.
von
Electrical powered!
When using since it was in high rpm, it got much heat in matter of short minutes.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @arsenbongat
You would need to use an AC motor speed controller but to find the correct one you would need to know the voltage required by the grinder and also it's power rating. Usually the model number will help to find this out.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
@jayep or rather can I used step down transpormer 220 to 110 volts?
von
@arsenbongat
Is the grinder designed to operate on 220V or 110V?
A step down transformer will reduce the voltage but then the motor may not turn or it will turn more slowly and will quickly heat up to the point where it burns out, which is highly likely
Good way to potentially destroy the grinder.
Get a speed controller that is designed to be compatible with the mains supply voltage and the appliance that you wish to control i.e. AC speed controller suitable for 220V mains input to use with a 220V grinder
von
Antwort hinzufügen
Arsen Bongat wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 188
