Zum Hauptinhalt wechseln
My generator is on but can't produce current to the house
I put on the gen and the house was powered but later the power went off while the generator was still on
What may be wrong?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Did you review your owner's manual for troubleshooting? No manual, try online from the company or this link, https://www.manualslib.com/manual/330724.... Is there a resettable fuse on this unit? Disconnect this unit from the house line and plug in a light for simple tests of generator output. I familiar with using a multimeter, measure the outlet(s) on this generator for power. If zero power while generator engine runs, either advanced troubleshooting as a diyer or bringing it to a small engine repair shop with expertise in generators. You might get lucky and find a youtube video or two on diy troubleshooting.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @stephenkin80895
There's a wiring diagram on p.24 of the owner manual that might help.
It shows there's a 20A and a 30A circuit breaker on the 120V AC output and also a 9A fuse on the 12V DC output.
Check if the breakers have tripped (either or both).
If one has then there's been an overload condition connected to that output supply.
Check how many appliances etc may be connected to that output. If they were all on at once they may have overloaded the circuit breaker causing it to operate.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
stephen kingsley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 158
