To change the speed of performance the laptop
How to make a faster this laptop type, what is the trick and tips for make this laptop to be faster for running application for graphic
Ist dies eine gute Frage?
Upgrading to an SSD and maxing out the RAM made the biggest difference for graphics apps. Also, keeping drivers updated and closing background stuff helps a lot. Don’t bother with “speed boost” tweaks, real gains come from hardware and cleaning up the system.
War diese Antwort hilfreich?
Thank you Monica for your answer
@tiyo55272 this is a laptop where the processor is soldered to the motherboard. You can't change that. This will leave you with the options to max out the RAM and, if you are still using a HDD, to replace that with an SSD. We will need to know the exact model number for you laptop to see what memory and what drive you would need. Besides that, there is not much else you can do. Graphic applications are very processor intensive and your computer may just not be capable of running those newer programs.
In the standard installed is windows 7, if i have change the windows 7 with win10 and i change HDD to SSD is it works?
@tiyo55272 it won't increase the processing power. Also, your computer may not take a Windows upgrade. Let us know the exact model so we can check on that too.
Aspire E 11
E3-112-C1KV
@tiyo55272 see if something like like this will work for you. Remember to upgrade your hardware first. You need the memory and the faster drive first. Make sure that whatever you do, you need to backup your computer.
Ok thank you for your answer dan attention 👍
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 93
