Zum Hauptinhalt wechseln
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
Removing Mold from the internal display frame
I live in quite a humid country and I encountered so many time a moldy inner frame from the A1278 models display. This part alone is not available as a separate piece or even worth to buy considering the overall value of these old MacBooks, anyway, damp is obviously a cause of mold, so cleaning one of these up to recycle is a bit of a challenge long term. What method would you recommend to use to get off the mold? I have been scratching off as much as I can and then sanding it down and then using some 99% ISP to finish it off before spray painting them black to give them some sort of 'protective' coating afterwards. @danj have you ever had to do this before? Interested in any suggestions. Thanks in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
A mild solution of bleach is about all I can think of using distilled water. Some bathroom tub cleaners offer stronger chemicals which will attack the heavier stains, wear proper PPE as they can splash burning you.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Bleach haha I forgot all about using that, I clean the bathroom every other day with some nice lemon fresh :)
von
Antwort hinzufügen
livfe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 104
