Zum Hauptinhalt wechseln
2,26 oder 2,4 GHz/ weißes Unibody-Gehäuse aus Kunststoff
MacBook turns on and then off abruptly, can it be the charger?
I’ve been trying to turn on my MacBook for about six days now, and I really don’t understand what’s happening. I already took it to a technician, but he didn’t seem to know how to handle the issue.
This MacBook originally belonged to my uncle. He upgraded some components, then years later gave it to my grandmother. It stayed unused for about 4–5 years. I turned it on once after that and it worked perfectly, but I stopped using it because it had an admin password that no one knew. I was younger at the time and didn’t know what to do.
Now, about 6–7 years later, I tried turning it on again. After charging it for a long time (the MagSafe light stays green), it powers on but then shuts off abruptly during startup. After it turns off, I have to wait several minutes before it responds to the power button again.
Here’s what’s happening precisely:
Power / Boot Issue
  • The Mac turns on normally, shows the Apple logo and the throbber.
  • It shuts down before completing the boot process.
  • The shutdown is abrupt, like the power is suddenly cut.
  • After it turns off, it doesn’t respond to the power button right away — I have to wait a few minutes before it will turn on again.
Fan / Internal Noise
  • I hear clicking or buzzing sounds that seem to come from the fan or possibly the hard drive area.
  • The fan appears to spin.
Magsafe
  • The green light takes about 5–8 seconds to turn on after connecting.
  • Once it turned orange for 4 seconds, then switched back to green. Probably is poor contact.
  • The MagSafe port has been cleaned, but the behavior remains the same.
Battery
  • With the battery disconnected, the Mac does not power on using only the MagSafe adapter.
Other Details
  • No burning smell or unusual odor (just a normal old plastic smell near the keyboard/screen area).
  • The screen lights up normally during the partial startup.
  • Startup chime is present.
  • The Mac is always cold and has never overheated.
  • Internal components do not show signs of corrosion, moisture, or staining.
I’m especially worried because the hard drive contains important family memories that I would really like to recover. I know the hard drive could be accessed with an adapter using another computer, but I’m 15, in Brasil (Things here are expensive), so I was hoping to repair this Mac myself and change to linux so I could also use it for studying.
I would really appreciate any help or advice.
So, could the MagSafe be solely to blame for all this? A few weeks ago I discovered that MagSafe is the 40W version, not the 60W one, and it isn't an Apple original. My grandmother bought it thinking the Macbook was a Macbook Air.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
40w or 45w L-Tip Charger? as I believe all MB Airs used a 45w?
von
Yes, it is a 45W L-Tip charger, I misread it earlier.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
As this system is on its last legs, I think it would be smarter just saving the data it holds.
From your description it sounds like the Battery is worn out! These batts didn't have a long lifespan so while the MagSafe cord LED will report a Green LED the battery's depth of charge is not able to sustain the system. You likely get the startup Bong depending on the version of OS it has and/or if the setting was altered as some people didn't like it.
So if you have your own Mac system then we should be able to salvage the data!
Here we need to get a USB drive case like this one 2.5" Hard Drive Enclosure with USB 3.0 Cable which will hold your grandmother's systems drive. Here is the guide to take the drive out MacBook Unibody Modell A1342 Festplatte austauschen.
Depending on your system you may need an older USB to the newer USB-C adapter to connect in the drive case.
A few warnings here!
Don't plug this drive into a Windows or Linux system as that could destroy the data on it.
I'm assuming the password was either the firmware PIN and/or user access password. As long as the drive its self wasn't encrypted you should be able to get to the pictures and text files. Some files may require an Application to access.
I strongly recommend you copy off the user folder to your system before touching them discretely so you don't risk the originals.
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part. Bild
Produkt
$12.99
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
I think the laptop is still working but a 40w charger isn't strong enough to power this system. I agree the battery is likely dying if not already dead. Realistically they have 2 choices, a 60w charger + a fresh battery for longer use or the external adapter + access to another computer (preferably a mac) to try to access the files... the drive I think will work still, it's maybe just not getting enough power from a 40w charger to function correctly on a system that requires a 60w input.
von
@livfe - Without the proper charger and a fresh battery ($$$) this system won't work at the needed level and there maybe other things that need attention.
Remember Esther's goal is to recover the files, taking the drive out is quite easy and sliding it into a case is not hard either and still cheaper. But the real question is does Esther have another Mac system to plug the drive into?
von
Well, my godmother has two MacBooks that I can ask permission to use, but my uncle said I should buy a proper MagSafe and battery before trying anything else.
von
@esther84836 - Nothing stops you putting the drive back into the system once you have what you need and it allows you to bypass the password.
von
If we can address some of the issues listed:
The shutdown is abrupt, like the power is suddenly cut = You mention it was unused for some years, the battery is likely in need of replacement as it may not be able to supply enough juice to power the laptop as a 60w charger is required to give enough power to the system when it is loading, as this is a time when it will require adequate power, if the battery isn't charged enough or taking or holding a charge then the system will indeed shut down.
I hear clicking or buzzing sounds that seem to come from the fan or possibly the hard drive area = Sounds like the hard drive is failing. A click sound is a tell tale sign of a failed drive. The fan will spin at higher speed when the battery is not connected or faulty, causing it to go into a 'safe mode to prevent overheating etc. OR this is due to an inadequate power supply as a 60w charger is required.
Once it turned orange for 4 seconds, then switched back to green. Probably is poor contact. = This suggests a battery that cannot accept a charge or isn't pulling the required voltage due to the use of a 40w charger.
With the battery disconnected, the Mac does not power on using only the Mag Safe adapter = A 40w charger is not powerful enough to run the system alone or to adequately charge the battery (Which I think being unused for such a long time will no longer function or hold a decent capacity).
So, could the MagSafe be solely to blame for all this? A few weeks ago I discovered that MagSafe is the 40W version, not the 60W one, and it isn't an Apple original = This system requires a 60w charger to properly power the system, so a 40w would not provide an adequate supply which is likely the cause of the sudden shutdowns as at boot the system will be in need of full power, this would also charge the battery at a much slower rate than normal and possibly cause some damage along the way.
The 1st step would be to find a 60w charger and see if you can get into the system to then check the batteries status and then if possible download CoconutBattery to see a more detailed information of the batteries condition. You will need to scroll down to get the version compatible with your current OS.
Post that info here if and when you can and we can go from there. The 40w charger is indeed your immediate and hopefully your only issue in getting this old lady back up and running.
Bewertung 1
First, lots of good comments from livfe. I have worked on and had MANY of these old MB A1342. I actually run one from time to time that i have a 45w power charger for, and that is enough. But, it depends a bit of what hdd you use, some take more power, some less. And it depends if your MB still tries to charge your battery, which i suspect has died. What you could try, is to put it in a special mode...that i forgot what its called, but it bypasses the charging system, and fan control etc. You do like this: disconnect the battery and charger. Press and hold power button for 10 seconds, then connect the charger still holding the power button for another 10 seconds. Then let go of the power button. Then press it normal once. Now the MB should power up, with the fan spinning at maximum. Its a bit loud, but this trix can start up many "dead" MB/MBP, from my own experience.
To be more precise, the MB A1342 I still have has a burned Magsafe-plug/board, so i made a special soldering + connection that makes it possible to run that MB without a battery on only a 12 volt, 3,33A power supply (40 watt). Its a "freak-Mac", but it proves you CAN run those machines on only 40 watt power.
Bewertung 0
Antwort hinzufügen
Esther wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 114
