Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für Fahrzeuge der britischen Automobilmarke, die 1903 gegründet wurde.
Clear dash board lights "service vehicle soon" " check left deep beam"
The service vehicle soon and check left deep beam light and check right deep beam lights are on. How can they be permanently erased
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hi @emman26169
What is the model and year of the vehicle?
Have you checked that both the L and R low and high beam headlights work?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You will probably need access to an OBD diagnostic tool to reset error codes, these can be found on certain auction sites and other places or if you visit to a local garage they may do the job for a fee.
The only other thing that may need checking that the new headlight module doesn't require coding to the car if it is connected to the CAN Bus, I have had this issue when changing certain modules on Volvo cars.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thank you Simon for that answer, should the new headlight module require coding assume it's connected to the CAN Bus, how or where can it be fixed.
Thank you
von
Antwort hinzufügen
EmmaN wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 94
