Zum Hauptinhalt wechseln
Die Wii erschien in Nordamerika im November 2006 und war Nintendos erste Heimkonsole, die direkt Internetkonnektivität unterstützte. Sie ermöglichte sowohl Online-Spiele als auch den digitalen Vertrieb von Spielen und Medienanwendungen über den Wii-Shop-Kanal.
"System Files Corrupted" error when accessing Wii settings menu
I got an RVL-001 Wii from a thrift store. It is unmodded and on version 4.3U as far as I can tell. It reads discs well enough to display the game channel correctly but won't start them. It also throws a "system files are corrupt" error message when I try to access the Wii settings menu, but I can access the data management menu. I've deleted some channels thinking it might be a banner brick issue. Starting in maintenance mode doesn't help, either. I tried installing homebrew through the bluebomb method but have been unsuccessful. Is this salvageable, or is the thing bricked?
Ist dies eine gute Frage?
Bewertung 0
9 Kommentare:
Do you have a way of accessing the storage formatting option? If so, I'd recommend you try that. ...Just make sure you've got all the channels you want to keep on an SD card so they don't get deleted if you try this.
von
@fixerofstuff The formatting option is in the Wii settings menu, so no, I can't access it. Is there possibly a button combination that would do the same thing?
von
Have you tried removing the SD card? Apparently that can help.
von
And no, there doesn't seem to be a button combination to format the memory.
von
@fixerofstuff No luck, I get the same results with or without the SD card inserted
von
4 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Back up your data and save states, and factory reset or format the Wii.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
The main problem is that I cannot access the option to reset/reformat the Wii as the settings menu crashes as soon as I try to open it. Or is there another way I can reset without accessing the settings menu?
von
You might be able to try and access the system files if you plug a pc into the USB ports.
von
But I don’t know if that will work
von
Update for those in the future who find themselves with the same problem. Using version 0.8 of the hackmii installer made the bluebomb method work. I was able to save a NAND backup and use that with ohneschwanzenegger to create a fresh NAND
Bewertung 0
Antwort hinzufügen
despencito wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 253
