Removing fractured glass bezel
Apple replaces the whole screen in this case, which is a large waste of resources (I am not replacing screen, I am just replacing the bottom strip that protects the flex cables). Problem is the flex cables are right under the bezel, so clearly any wrong poke into them would break them and cause a full screen replacement to be necessary. I was thinking of doing [something like this](https://www.youtube.com/watch?v=DrQM4EZO...), only the model is different so I am concerned I may break something without realising since I assume the design is the same as the model shown in the video. Any experience / suggestions? So far all the repair shops I've been to just want to replace my entire screen, yet M2 Macbook Air bezel replacements cost 15 bucks on Ebay.
P.S. The teardowns I've seen only show the parts connected to motherboard, but don't attempt to dismantle the screen.
Ist dies eine gute Frage?
3 Kommentare
Could you take some pictures for context, I feel like the issue you're running into can only be fixed by replacing the whole screen. but some photos could help.
von JRock
@ry63184 [This](https://codeberg.org/jipmelon/t/raw/bran...) is it (actual display is 100% intact)! If you zoom right in you'll notice the material covering whatever may be underneath has been warped, so a part of it peeled off, revealing some shiny metallic rectangle. If it weren't for the fact that the glass would break in a million pieces, that could also be a good entry point for prying the whole thing out - maybe I should superglue / resin the cracked glass zone and *then* try and remove the entire bezel? In the video they used slight heat, controlled drops of alcohol and sharp paper (rather than plastic or metal, as it was supposed to be more delicate) and were able to get the bezel out on an older MacBook Pro.
von Alessandro G
Cover the whole glass with clear tape so if it shattered then the tape would contain the fragments ;) I suggest to replace the whole display assembly in any case. @danj for his opinion.
von livfe
