iPhone 13 Pro Max Screen Issue: Green/White Vertical Lines After Batte
based on the images, is there a 100% confirmation that this is a hardware failure of the panel and not just a corrupte
d screen driver/connector issue?
Ist dies eine gute Frage?
That is a broken screen. I would get it replaced or if you feel comfortable, you can replace it yourself. The guide is linked here: iPhone 13 Pro Max Display tauschen
War diese Antwort hilfreich?
Yes that is absolutely an issue with the display panel. I'd recommend replacing with a premium soft OLED panel or OEM screen if you can source one if you plan on keeping it. LCD replacements are cheaper but they're thicker and require more energy to run, so you'll notice the phone running warmer and drain battery quicker.
You can source a soft OLED from ifixit here iPhone 13 Pro Max Display tauschen
Or you might be able to get an OEM screen from the self service repair store, but be aware, apple sells their parts like they're gold plated. https://selfservicerepair.com/en-US/ipho...
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 60
Insgesamt: 334
