The 5th generation 2011 Explorer bore similarity to the Explorer America concept's construction, and includes a unibody structure based on the D4 platform.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar:
What year is your Explorer, and is it 2WD or 4WD? That will usually affect how the rear brakes are accessed.
By "do the brakes", I assume you mean replacing the brake pads? Are you wanting to flush the brake system with new fluid too? Is there anything else you consider to be part of doing the brakes that I haven't mentioned?
von Jerry Wheeler
