Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlerdiagnose für Beats Solo 4. Identifizierbar durch die Modellnummern MUW23LL/A, MUW43LL/A und MUW33LL/A.
My beats will not charge even after I try multiple cables and outlets
when I try plugging my beats into a wall socket or my computer the light continues to stay red and my phone is telling me they are just sitting on, I have tried multiple different USB C ports and the correct bock's for them but they have not worked, also my manual says that the light should turn red when charging but the light color haven't changed during my testing.
Update (03/27/26)
ps. my beats are less than one (1) year old
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@tylerkelley sounds like your Beats are doing what they are supposed to do, except charge. That would lead me to suggest you start off by replacing the battery. Yes, I know you've said they are only about a year old, but the battery could be older and may actually have failed. If nothing else, a new battery will give you a known-well starting point should any further troubleshooting be necessary.
Once you have your Beats open, take a good look at the wiring. Check for broken , loose wires, corrosion damage etc. you can always post some pictures of what you find with your question. That way we can see what you see. Bilder zu einer vorhandenen Frage hinzufügen
Since iFixit does not yet have a guide for that, use something like this video to work on it. Batteries are readily available at many online stores.
While you work on your headphones, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
tyler kelley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 28
Letzte 30 Tage: 99
Insgesamt: 476
